Playing dvd's stored on hard drive?
Discussion in 'Desktop & Laptop Computers Forum' started by minimivic, Apr 24, 2002.
  1. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Is it possible to store and play DVD's from hard drive?
    What software do I need. I use Power dvd at moment and tried using smartripper to rip the DVD. It ripped ok jusr wont play.
    Any other ideas
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    I think you'd need something to merge the VOB files together and then a player that will play VOB files (I'm sure Power DVD does).
  3. rob_w
    rob_w
    i`ve got windvd and this plays rips from "dvddecrypter" ok, just doesnt allow menu use...
    have to create a playlist in windvd of the vob files and save the playlist, then play it...
    hope this helps a bit..
    rob
  4. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    I loaded win dvd and can play the vob files now.
    I cannot use power dvd to play them. Just stops instantly.
    Win DVD3 is a bit stuttery compared to power DVD. I cant patch it to 3.1 to be XP compatable so that maybe the problem.
    Also files that are stored havent got chapters like on DVD, anything that can be done about it.
  5. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Zoom player, plays the menus too
  6. Splice
    Splice
    Mar 16, 2002
    162
    16
    Buckinghamshire
    I am not using power dvd at the moment but I have done this with it. I think you are in disc mode. on the user interface there is a small icon that represents a disc. if you click on this you will then go into file mode, where you are able to make up a playlist of vob files to play.I think, if my memory is working right, the icon is towards the right of the player interface........thats on the default skin (i think).sorry cant be more specific.
    It worked great for me.
    All the best........Splice.;)
