Playing DVD-A discs on a 5.1 system
Discussion in 'Blu-ray & DVD Players & Recorders' started by Tracey, Aug 13, 2003.
  1. Tracey
    Tracey
    Hi, I have been investigating DVD-A and I may consider upgrading my DV27 in the future, but I just wanted to know if anyone has any experience of playing a DVD-A disc on a normal 5.1 system. From what I have read so far it appears that I will get DD 5.1 surround sound and I can also play the discs back in stereo using just the front two channels, but would this sound worse in stereo than buying the normal CD version? Also can you record from DVD-A discs? I don't copy discs for anyone else but myself I just like to do compilations rather than having to listen to an entire album.
    Tracey
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    If you want to know all about DVD-A , look on this DVD Demystified link, it's a little out of date but will give you an idea.
    The stereo on the DVD-A will not sound worse than your normal CD , it will be better.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,897
    +1,671
    Only if you're playing the 24/96 or in some cases 24/192 stereo track if this is available,and your DAC is up to the task....also depends on the quality of the analogue stages in your player.
    As yet,only Pioneer,Denon and Meridian produce systems which will allow transfer of encrypted digital data direct from the player to processor at full resolution...otherwise you rely on decryption/decoding within your DVD-A player and analogue output from there.
    The DD track can sound very good,but may suffer from the usual DD bass problems......discs with DTS tracks available can sound excellent.
    As for recording,if you look at the HiFi Press recently,you'll find alot being said about copy protection on DVD-A,and the various watermarking techniques....basically it's stored as encrypted digital audio on the disc,and if you get any output via the digital out on your player,it will be at 16bit resolution.
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Didn't make myself clear , but what I was talking about.
  5. alexs2
    alexs2
    Nov 13, 2002
    13,897
    +1,671
    :) Just a shame that the format war continues,and all this encryption goes with it...also the problems getting some DVD-As to play on certain players in the first place,due to the somewhat messy protocols(or lack of) for audio replay from DVD.
  6. Tracey
    Tracey
    Thanks for the info everyone, very helpful. :smashin:
