playing DTS-HD blu-ray with an older av receiver with no HDMI
Discussion in 'Home Cinema Buying & Building' started by zicolofoo, Jan 28, 2014.
  1. zicolofoo
    zicolofoo
    Nov 18, 2009
    11
    Pls excuse me if this subject has been discussed. Not able to find the right thread.
    To play Blu-ray movies with True HD audio, such as "DTS-HD" with an older receiver without HDMI connection, i can only use its optical or coaxial. Any advice how am I going to get surround if the Blu-ray has only "DTS-HD", and no other usual 5.1 options?
    The rear speakers were not activated when i played a disc with only DTS-HD, seems like I am getting stereo instead of surround.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,927
    The Borders
    +3,573
    Optical/coaxial Digital Audio doesn't have the bandwidth to support Dolby/DTS HD audio - you need HDMI or multiple RCA for HD to your AVR.
    Your player will access the 'core' DTS info and play that out over Optical/coaxial (at a higher bitrate then DVD).
    Unless you know a movie soundtrack well enough to select passages which give your surrounds a workout you may want to find a test disc.
    If your BD Player has settings for Speaker size/distance/sub crossover and you have multichannel audio in on the AVR you can output the HD audio using a suitable converter - Media Factory - Octava HDMX71-UK, 4x2 HDMI Switch with 7.1 analogue audio.
    Joe
