Playing Dolby Atmos discs
Discussion in '4K Ultra HD Blu-rays' started by RetroDaz, Dec 19, 2017.
    1. RetroDaz
      RetroDaz
      Nov 7, 2014
      78
      11
      Bournemouth
      +8
      Will I be able to select Dolby Atmos 7.1 if I only use a 5.1 set-up? (My amp does output Atmos and is 7.1, I just don't have extra speakers).
    2. simonlewis
      simonlewis
      Jul 31, 2014
      4,138
      stockport
      +1,512
      You will need a 5.1.2 for dolby atmos.
    3. StumpyBloke
      StumpyBloke
      Feb 6, 2006
      2,674
      Stone, Staffordshire
      +993
      Your amp shouldn’t be set up for Atmos if you’ve configured it correctly so just play and enjoy.
    4. RetroDaz
      RetroDaz
      Nov 7, 2014
      78
      11
      Bournemouth
      +8
      What does that set up configure? My amp definitely does atmos.
    5. RetroDaz
      RetroDaz
      Nov 7, 2014
      78
      11
      Bournemouth
      +8
      So you can't select atmos if you don't have the right speaker set up?
    6. StumpyBloke
      StumpyBloke
      Feb 6, 2006
      2,674
      +993
      You can select the Atmos track on the disc but any overhead stuff obviously won’t be played because you don’t have the Atmos speakers in place [emoji106]
    7. simonlewis
      simonlewis
      Jul 31, 2014
      4,138
      stockport
      +1,512
      5 surround, 1 subwoofer, 2 ceiling.
    8. simonlewis
      simonlewis
      Jul 31, 2014
      4,138
      stockport
      +1,512
      Atmos is ceiling speakers, comes in 2 and 4.
    9. CarlB
      CarlB
      Jan 8, 2001
      1,307
      Cambridgeshire
      +230
      Without the ceiling speakers your amp will decode the Dolby TrueHD core track, even if you select an Atmos mix on the disc. You cannot decode and play the object-based Atmos track without the ceiling speakers, as mentioned. It makes sense at Atmos is designed to build a 3D audio ‘bubble’ which is not really achievable when you don’t have a height channel to add that third dimension to the configuration.
    10. RetroDaz
      RetroDaz
      Nov 7, 2014
      78
      11
      Bournemouth
      +8
      Thanks everyone. I was just concerned that Atmot simply sounded better in general and didn't want to miss out.
    11. Derek S-H
      Derek S-H
      Jan 2, 2005
      2,808
      134
      Brighton
      +1,625
      To the OP - Atmos does sound better and it is worth investing in some extra speakers.
      Upfirers which sit on top of your existing Front L&R (to create 5.1.2) and Rears (to create 5.1.4) is a compromise compared to in-ceiling speakers, but are easy to fit, look good and sound fantastic.
      Most AV amps provide sound upmixing, which means even non-Atmos discs like DVD or games are recreated using pseudo Atmos and it really opens up the sound.
      I can't imagine going back to just 5.1, it would just sound so small in comparison.
    12. doug56hl
      doug56hl
      Feb 27, 2006
      4,188
      +2,482
      Not strictly true. You just need speakers connected to the height channels and the receiver configured for Atmos/DTS-X. These speakers can be at any height, even on the floor....
    13. series1boy
      series1boy
      Apr 15, 2011
      187
      Sheffield
      +51
      I have front and rear heights. Sounds brilliant!
    14. big boss
      big boss
      Feb 15, 2009
      1,219
      +348
      Yes, but it's the height gradient which creates the Atmos effect. Sure, you can place satellite speakers on the floor and assign them as Atmos speakers for example, if you want the helicopter to pass under you instead of over you. It will sound all wrong and opposite to what's on the screen. When setting up the AV receiver, you'll need to specify where the Atmos speakers are; on the ceiling or as height speakers on the wall.
    15. Ter
      Ter
      Nov 20, 2015
      55
      11
      Scotland
      +21
      Interesting conversation! I have a 7.1 configuration at the moment and just upgraded to a Denon AVR-X3400H amp which, although it supports Atmos, is limited to 7.2 and ad such I cannot just bung in another couple overhead speakers without changing the existing setup.
      I'm thinking of repurposing the rear surround channels to overhead, but wondering if I can get away with their existing location which is in the reference position, but due to limitations in the room layout, placed at ceiling level and angled downward.
      Any thoughts?
    16. Jim Di Griz
      Jim Di Griz
      Jan 24, 2009
      17,557
      Darkplace Hospital
      +8,478
      Definitely upgrading to 5.1.2 soon - easy to do and relatively inexpensive as a bonus.
    17. series1boy
      series1boy
      Apr 15, 2011
      187
      Sheffield
      +51
      I’m sure if I installed proper in ceiling speakers, it would be a more enveloped experience. However, the front and rear heights in each corner of our living ceiling does a great job. The best disk I have used is the latest transformers and you can defo here the planes shooting over you :)
    18. doug56hl
      doug56hl
      Feb 27, 2006
      4,188
      +2,482
      You seem to have missed the alluded point of my previous post (Dolby upfiring speakers).
      An example floor standing dolby atmos speaker SP-EFS73 - Dolby Atmos® enabled Elite® Concentric Floorstanding Speakers designed by Andrew Jones
    19. doug56hl
      doug56hl
      Feb 27, 2006
      4,188
      +2,482
      Are you saying your rears are mounted as heights already?
      If so, you can configure them as 5.x.2 without having to do anything else and see how they sound.
    20. series1boy
      series1boy
      Apr 15, 2011
      187
      Sheffield
      +51
    21. big boss
      big boss
      Feb 15, 2009
      1,219
      +348
    22. RetroDaz
      RetroDaz
      Nov 7, 2014
      78
      11
      Bournemouth
      +8
      I feel I am missing out on atmos and have been thinking about buying some speakers. Does anyone have any suggestions for some upfiring speakers around the £150 mark?
      My cousin is an electrician and could fit speakers but I feel this would be a lot of hassle,
    23. maturestudent
      maturestudent
      Feb 22, 2012
      135
      +51
      You can use any speakers just point them upwards so the sound bounces off the ceiling. Only thing I've noticed is the room fills with audio, and is much more immersive. More fuller if you get what I mean.
    24. series1boy
      series1boy
      Apr 15, 2011
      187
      Sheffield
      +51
      I tried the onkyo upfiring speakers and they were rubbish; cheap and nasty in my opinion!
      Take a look at this link, interesting:
      Can I Use Regular Speakers as Dolby Atmos Upfiring?
