Playing CDR's on DVD Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by griff57, Mar 12, 2002.
  1. griff57
    griff57
    Hi. I own a Grundig GDV210A DVD Player.
    Apparently, it seems it is relunctant to play CDR media, so I am wondering if anybody out there knows whether or not it is possible to convert it to do so.
    Help Please.
  2. Ron240
    Ron240
    Jan 3, 2002
    3,614
    Kirkcaldy (but i'm not a Fifer)
    +465
    Sorry,but i think you are out of luck here.Most of the newer DVD players are designed to be CDR/RW compatible,its to do with how the laser focuses on the disc.It can be a useful thing to have but if yours doesnt do it then i dont think it ever will.
  3. paiger
    paiger
    Apparently Princo CDR's are the only ones that will work on Sony 700 series DVD's so they may be worth a go. My 735 won't play CDR's but will play any CDRW, bit more expensive but getting cheaper now and you can always re-record when you get bored.
    S
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    CD-R/W requires compatible hardware, so no upgrades here. You can however as suggested try CD-RW media.
  5. GarethH
    GarethH
    Aug 31, 2000
    325
    UK
    A new type of CD-R dye which is a light green is coming onto the market soon! It has the following advantages
    - 20 Times Longer Life than a normal CD-R in which the quality of the burn stays the same as the day it was written!
    - Compatible with "ALL" CD-ROM Drives and DVD Players
    - High Burn Speeds
    I've heard this on many CD-R dedicated sites. I'm not sure how much the discs are going to be but i'm looking forward to seeing them.
    I'll let you know if i find more!
