Playing CD-R's on a DVD player
Discussion in 'Blu-ray & DVD Players & Recorders' started by owenmj, Apr 27, 2002.
  1. owenmj
    owenmj
    It was a bit of a bonus to find that my Sony DVP-S735D DVD player plays CDs, but a big disappointment to find that it won't play CD-R's. My old CD player plays CD-R's fine.
    Is there a software hack or a hardware chip to get round this?
    Regards
    Michael Owen
    (No relation to the England skipper!)
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    I somehow doubt it, the ability to read different media like CD-R is usually a feature of the drive mechaism and in particular the laser.
    Is it not reading a CD-R copy of a CD, or is it MP3 files that you are trying to play ?
    Features like playing MP3 files might be added by firmware changes, but if it can't read a normal copy of a CD then you are unlikely to fix this.
    Mark
  3. owenmj
    owenmj
    Mark,
    Thanks for your comments. It's playing CD copies rather than MP3's that I had in mind, but I would be interested to know how I might play MP3 files. How would I do the firmware adjustment you mention ?
    Michael Owen
  4. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,777
    EU
    +813
    Hi Michael,
    As Mark says, if your DVD player can't read CD-Rs anyway, then it definately won't play MP3s as they come on CD-R discs. It's best to ascertain this first with a normal CD-R recording.
    I've heard that some DVD players which can't read CD-Rs can play CD-RWs (re-writable). I'm not sure how true this is but it might be worth a try for the cost of a blank CD-RW.
    RDB :)
    PS Sony DVD players are notorious for not playing CD-Rs but it seems to be OK on the DAV series for some reason.
  5. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Michael
    The DVP S735D is not capable of playing MP3's.
    As for CDR the only ones reported to work are Princo ones.
    However CD-RW do work.
    Hope that helps you.
    Bry
  6. owenmj
    owenmj
    Bry,
    Thanks for the advice, looks like I need some Princo blanks or a few CD-RW's.
    Thanks again for your help
    Michael
  7. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Anytime, good luck.
  8. Mike Dando
    Mike Dando
    My 725 plays CR-RW discs without any problems.
