Playing a SACD disc
Discussion in 'AV Receivers & Amplifiers' started by wallasey, Mar 3, 2003.
  1. wallasey
    wallasey
    Jan 1, 2003
    11
    I've got a Sony Amp STR-DB780 and a
    Sony SACD/DVD DVP-NS700 player I've connected using a optical cable when playing DVD's this works ok. I've just bought my first SACD and connected the amp to the player using imput jacks, but I only get sound from one speaker, I've read the manuals and I think everything is set up correctly can anybody offer any help?
  2. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    You need to use analog connections for SACD.
  3. wallasey
    wallasey
    Jan 1, 2003
    11
    I thought the imput jacks were analog the are wired to 5.1ch output to 5.1ch input
  4. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    Ahh, I'd miss read that bit. I presume you are setting the amp to 5.1 channel input?
    Check you have all 6 cables wired up correctly, if you still only get sound from one channel then something is a bit broken somewhere. By swapping connections round a bit you should be able to work out whether it's the DVD outputs, a cable, or the amp input.
  5. vee_cee
    vee_cee
    If you've connected player to amp correctly, with a 6 phono to 6 phono cable....
    Then all i can think is ..... there must be some setup to do for either the player or then amp or both?
    Worth a go
    VC
  6. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    In the DVD players menu there's a section relating to speaker size/distance settings - these are related to the onboard SACD/DD/DTS decoder. Have you checked to see that all speakers are set to small or large as opposed to "off"? The DVD player will downmix the sound to however many channels are activated if you have some speakers set to "off".
    Worth looking at if you are still having problems after trying the above.
    K.
  7. roofer
    roofer
    Nov 21, 2002
    343
    northumberland
    +10
    you need to press the input selector on your amp and select the input you require not the coax or optical input the other one
  8. stranger
    stranger
    make sure you select sacd on the dvd player and2 ch or multi ch.
