Playing 4K files from Plex Server Issues
Hello and apologies if this question is in the wrong place or already asked, I spent some time looking on the site and couldn't find a match
I'm hoping someone with the know-how or knowledge can either point me in the right direction or even help me troubleshoot the problem.
Basically I am trying to play 4k video files from my Plex Server with the files themselves stored on my NAS. Some files work great and others just stop/start every second (I presume buffering?) but I have no freaking idea why. I have set Plex to prefer to 'Direct Stream' as I feel that transcoding will create more issues (?) So I don't know if it's a bandwidth issue on my LAN? My CPU not powerful enough? Not enough RAM on the plex server? File type issue? I really don't know. Some files make my cores hot and I get warnings. Other files seem to just work?
The specifics:
Plex server - 64-bit Win 10 Pro i7-8700 CPU @ 3.20GHz 3.19 GHz with 16 GB RAM
NAS - Synology DS 1821+ running DSM 7.0-41890
TV - Samsung TU8000 55" UHD 4k (2020)
4x4 HDMI Matrix Switcher (PS4 Pro plays file with Plex app (client) via switcher to 4K TV)
PS4 Pro (seems to play more files than the Shield)
Nvidia Shield (struggles to play most files tested)
By way of example I have added some screenshots of my plex server whilst playing a test file that works and 2 others that don't in the hope someone might see something that has so far eluded me and might say; "Ah-ha!"
Screenshot explanations as follows:
non-working file test 01: This file just won't play. Bandwidth seems to be topping out but I've really got no idea how to interpret the graph
non-working file test 02: Different movie but same issue. It seems to want to transcode it but I'm not sure why
working file test 01: Different movie and works relatively well. If I was super picky it's not as smooth as I'd like it on screen but others I showed couldn't pick it
If I've left something out or more data is required please feel free to get back to me. If you have a suggestion or can pinpoint an issue can you please use laymans terms as I am not very technical!
Thanks in advance and thanks for reading
Ray
The specifics:
Ray
