Player Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Leeray3, May 8, 2001.
  1. Leeray3
    Leeray3
    Jan 22, 2001
    149
    London
    Help me please!!! My Sony DVD player does not work. On friday night the picture froze whilst watching a film. I ejected the disc as nothing would work. Now when ever I put a disc in the player goes into thinking mode and then states that there is no disc. I have tried Region 1 & 2 discs and CD's. And I get the same message every time.
    The modification was made before it was delivered by multiregion magic. So it's not a cowboy job.
    Has anyone had this problem and can they help?
    The player is a Sony DVP-S735 :eek:
  2. stefinch
    stefinch
    YES I have had exactly the same problem as that before but with a different player. Picture froze and then wouldn't play a thing just said "no disc". The problem was a faulty laser.
  3. I am maximus
    I am maximus
    Nov 14, 2000
    76
    Surrey,UK
    I had the same problem with a Panasonic A350,it read the discs as being dirty but it was a faulty laser it needed to be replaced (very expensive).I hope this helps
  4. Leeray3
    Leeray3
    Jan 22, 2001
    149
    London
    Thanks guys.
    I contacted the branch that I bought this player from and they told me that the laser needed to be realigned. After trying this and still it was no good I returned it to them and was then told that the laser was faulty and that it would be sent back to the manufacturer and be replaced.
    I was lucky that it was still under guarantee
    Cheers :D
