degeneration
Established Member
I had my htpc up and built and all seemed good.
Watched a film on it the other day from an external usb hd, and was pleased with how it turned out. Playback was great. That was with it lying out and all the final bells and whistles not in place. i.e. booted to desktop, opened xbmc and then used it. I'd previously just plugged the drive into my tv before I built this htpc, and it always played back fine too.
I've now put it in the AV rack under the TV, had it set up with eventghost to start xbmc as a shell, for a more seemless integration, and have a remote customiser set up to start as well before the xbmc.
Watching a film for some reason there is frequent (every couple of minutes, no set frequency) stuttering of the a/v. the audio will repeat about a half a second of what has just been, then the picture will judder as it resynchs itself.
Thinking it was something to do with the way I had it all set up, I just tried it with windows booting to desktop, then opening xbmc, but the same still happens. I tried a second film just in case it was simply the source material, but the same problem was exhibited.
My hardware is:
asus m4a88t-m mobo
Athlon ii x2 250
2x 1GB kingston hyper-x blu DDR3 1333MHz
500GB HD
Films being played from external USB drive at the moment.
There does seem to be a reasonable amount of heat around the case, bios has the mobo and cpu temps as being around 45-50 degrees.
I don't know or understand why this stuttering has started, as it didn't happen two days ago.
Any suggestions to help would be greatly appreciated.
My hardware is:
asus m4a88t-m mobo
Athlon ii x2 250
500GB HD
