Playback problem on Panasonic E85
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dene, May 17, 2004.
  1. Dene
    Dene
    May 17, 2004
    Can anyone assist with this problem?
    I've just bought a Panny E85, but I'm not happy with the playback. I'm using the same, I've always thought top quality, SCART lead to connect the machine to my TV as I used to connect my Samsung 709.
    However, when playing a disc on the E85, it exhibits signs of having a weak connection -- a surface layer of extra grain, little moving lines around edges of things (very technical I know!). It's almost as if I'm not using a blinkin' SCART.
    Anyone got any suggestions? It's going back if this can't be fixed -- and I haven't even tried recording anything yet! Playback is quite a priority though...
    Cheers in advance.
  2. Ged
    Ged
    Apr 29, 2002
    949
    +25
    It may sound daft but have you enabled RGB out and used the right scart socket?
    It may be in the wrong one or your TV may need a button press to activate RGB.
  3. Dene
    Dene
    May 17, 2004
    That's spot on. Shortly after posting I discovered that you have to enable the RGB connection in the E85's setup.
    Cheers for the reply.
