Play/Record at the same time?
Discussion in 'Blu-ray & DVD Players & Recorders' started by iantowns, Oct 23, 2005.
  1. iantowns
    iantowns
    I have decided to take th plunge and buy myself a DVD recorder with a hard disk drive.
    I am a little confused as to which models allow you to record on to the HDD and view a DVD at the same time. I would find this feature particularly useful.
    Does anyone know which models offer this feature please?
    Many thanks in advance, :thumbsup:
    Ian
  2. Phantom Phixer
    Phantom Phixer
    Jul 23, 2005
    I would think most models with HDD allow this. The Pioneer models certainly do.
  3. smallmanongn
    smallmanongn
    I know the Sony 910 I am getting does but only if you are watching a PAL DVD
    I should think it is a standard feature on most of them and probably with the same "limitation" as the 910.
  4. iantowns
    iantowns
    Ta chaps. :)
    I had me eyes on one of the cheaper Lite-On 5045 models (which doesn't play and record at the same time), but it seems it's worth spending the extra to get a machine that will do it.
