Play.com usb ps2 convertor problems
Discussion in 'Playstation Forums' started by dougstar81, Jan 14, 2005.
  1. dougstar81
    dougstar81
    I have just bought this unit from play.com, i installed the software and it says it is working fine, there is no way of unistalling this software on the disc or i cant find it? can some one please please point me in the correct direction, all i want to do is get the software of my pc as it has messed up all my games, the menus fly around in circles as if the buttons on the controller are stuck on. Please can you help? :) :thumbsup: :lease:
  2. Marc
    Marc
    Jul 8, 2004
    11,627
    Titchfield
    +1,098
  3. dougstar81
    dougstar81
    Read the hole thing twice must be crazy cause none of those things will help me uninstall the software, can find any files of it or anythin...
