Play - certificate authority warning
Discussion in 'Blu-ray & DVD discs' started by bertha, May 19, 2005.
  1. bertha
    bertha
    Oct 25, 2001
    1,338
    +102
    Hello all - just about to pick up a couple of discs at Play (nothing unusual there) when I got a certificate authority warning message saying that the site may be dodgy or there may be some other problem..I'm using mozilla and bought from PlayUSA just last week - do you reckon it should still be cool or should I contact them to let them know that there may be a security issue - sorry if I'm being paranoid, it's a speciality of mine
    Berth :rolleyes:
    NB Just thinking.. I installed a Windows security update yesterday do you think there may be a connection there?
  2. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,204
    Chelmsford
    +504
    That's possible. I have bought from play hundreds of times and they have always been fine. I'm sure if you want to contact them they will look into it.
  3. Eitzel
    Eitzel
    Nov 3, 2004
    661
    46
    Top Secret-Anyone coming anywhere near my Pioneer
    +145
    I've also bought many, many times from Play (.com and USA) without any problems. If you are concerned, do get in touch with them.
  4. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    Could be the site not having the correct or up to date security certificate which is true for the vast majority of sites.
  5. Roughneck1
    Roughneck1
    My guess is that there site cert is in the process of being renewed, or its a server firewall issue for them.
    We have had this too... the site is 100% a secure as its always been though.
    Hope this helps...
  6. MikeFish
    MikeFish
    I got that warning on playusa yesterday too, so it's not your computer at fault.
    I logged into my account (thought the site may have been hijacked or something) and all my details were there and correct.
    Play.com seems OK though.
  7. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    I had similar problems with Mozilla and ended up taking it off my computer. No problems since.
    Seemed to clash with certain security protocols and caused firewall issues.
