Plastering speaker wire into a wall.
Discussion in 'Home Cinema Speakers' started by Mr Bump, Jun 5, 2003.
  1. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Any issues with this, in terms of interference etc? I want to plaster in the wires for my rears, for aesthetic reasons. :D
  2. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    Interference? None that i've experienced but my speaker wire is chased into plasterboard.
  3. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    I have solid breezeblock walls in my house, but it is flat wire, so it would only have to go in half a centermeter or so. I didn't think there would really be a problem, I just thought I better check with the experts first, just in case! :)
  4. mjn
    mjn
    May 24, 2001
    22,093
    Herts, England
    +9,848
    only problem is...what happens if you want to change the cables??
    you'd be better putting tubing in the wales, and feeding the cables into the tubing. That way, you could route any cables needed in the future or changing the cables without hassle.
  5. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    That doesn't bother me. If I decide to change the cables in a few years and have to re-do it all, no problem - I'd rather do that than have channeling up the wall.....
  6. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    Obvious...but ...just make sure you've no cable breaks... before you plaster... forgot this in my old house... and had to bolster my new plaster off the wall 3 weeks after it had gone up :blush:
  7. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Hehe. No, they are fine - been using them for a while on the outside - gonna now put they into the wall seeing as I am redecorating anyway! :)
  8. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    there was a tread over in the DIY forum about this called 'chasing plaster etc'
  9. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I did this with the rears, fonts went under the floor,not a wire in site.
  10. mumu
    mumu
    Is not a problem, I have just done this and it improves the look of the room no end.
    Just make sure that you also pin the cable back (especially near the ends where it exits the plaster) to prevent it accidentally pulling the plaster away.
    Alternatively create a channel in the wall for some conduit and then chase that in with plaster - can even replace the cables without replastering then.
  11. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    That would have been a nice idea, but my walls are rock solid, so it was a pain enough to take out the 5mm I needed to do this! Anyway, all done - and you're right - I think it will look miles better. I sodding hope so - it was bloody hard work! :zonked:
  12. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    The conduit i just used at a mates house was thin enough to surface mount on the solid wall and plaster over.
