My room has had its chimeny breast removed exposing the bare brick behind it. I've had the whole room replastered with Lafarge Easy Finish (Equivalent to Thistle Multi-finish I think), but with Thistle Hardwall then Easy Finish where the breast was. I now need to chase out the wall where the breast was for the AV cabling. The cabling will be in a "skirtingboard conduit" bought from B&Q so it will run from floor to plasma (conduit will be on it's end so to speak). I plan to the have the cap no more than 4-5mm from the surface and I like to know whether I should Hardwall over the chase and then finish off, or should finishing alone be sufficient enough? If I need to Hardwall, is it best to chase a little deeper and hardwall the recess then place the conduit in place and a little more hardwall to ensure it stays in place?
