jassco
Quick question for those savvy on building techniques. We had a porch built last year, and in fairness he did a good job. Where the external brick was present, he boarded over this using plasterboard that could be painted directly onto, and he used dot and dab to attach the board directly to the brick wall.
A few months back before we had the floor tiled, I noticed some damp in the bottom corner, but assumed this was because he boarded directly down to the concrete floor. So I took off the bottom of the board to create a gap, and that's been fine since.
However now I've noticed that the board, which is painted with good quality white paint, is turning a very subtle yellow anywhere that there is dot and dab, so moisture must be soaking through from the original brickwork. Also looking externally, our pointing (on both the porch and existing house walls) appears damp.
So my question is, was it okay for him to dot and dab onto the external (now internal) bricks, and if so where should we be looking to identify the source of the problem?
Happy to call in an expert, but I could do with knowing which expert is needed
