Plasmas been nicked
Discussion in 'Plasma TVs' started by Stimpy, Aug 7, 2004.
  1. Stimpy
    Stimpy
    Just come back from holiday and found that my house was burgled.
    The &&^%^&*s nicked my plasma and all the wifes jewellary.
    I havn't really been looking at the market these days, but what is
    generally recommended for a 42" plasma these days for aroun 3.5k??
  2. Marc_J
    Marc_J
    Aug 7, 2004
    5
    Edinburgh
    That's too bad....
    ...you need to update your sig, then :rolleyes:
  3. AV Junky
    AV Junky
    Oct 30, 2002
    1,211
    Cheshire, UK
    +68
    For that budget, I'd probably go for a HD model from either Pioneer or Panasonic (43MXE or HD6, respectively). Plenty of posts on these two to keep you going and help you decide.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Stimpy thats gutting mate! but £3.5k buys alot more plasma these days! see special offers forum. and have a chat to Joe Fernand and MAW but Fujitsu VHA/ Panny HD6 Pio 434 or even 435 when its out, Panny veira etc etc etc. Where abouts in UK are you?
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    What did you have 1st time round, and were you happy with it? Then we could steer you in the right direction, and maybe either save you cash or staggeringly improve things.
  6. Stimpy
    Stimpy
    I Previously had and LG pz14, it was a very good screen for the money at the time.
    The whole thing was driven by a Pro-V scaler and had a very good picture (even if I could not get the colours quite right with the THX glasses and test disk). In fact the picture was better via S-vid via the pro-V than via a direct component connection.
    Do current plasmas suffer strange motion problems especially when watching the footie???
    Also do they all come with sperate tuner boxes with inputs for component/rgb/S-vid/composite???
    Unfortuntaly the insurance company do a like for like replacement sourced from either Comet or Empire. That going to be a problem with the speakers they nicked as they were imported from the states (ADD E44s at £250 a pop) so I doubt I will get the same quality back. :mad:
    Cheers in advance.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    I would argue that point and ask for a cheque to made out to your local dealer. You may need to submit a quotation in order to settle the claim.
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Or else just get the Pioneer 434, if you are stuck with comet for a source. It's possible to do better for the cash, but you have to try quite hard, as a plasma TV they are 2nd to none. Separate media box though. There are numerous choices that don't have a separate box, both with and without tuners built in.
