D
digitalbanana
What Plasma (or LCD for that matter) would you recommend for using with a PC primarily for FPS gaming, like Far Cry, HL2 etc. and possibly using it for regular apps.
The limit being a budget of around 1,500 quid, and that high speed games should run great on it, as well as XBox (modified) connectivity and preferrably as big as possible for the price bracket, with good performance obvioulsy.
Also, any of you that have used PC's with large plasmas/lcd's have you had any problems at all and are they ok for using with a PC.
Cheers for any advice.
