Plasmas and fireplaces do they mix ?
Discussion in 'Plasma TVs Forum' started by newstuart, Aug 7, 2004.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    Hi again guys,
    I at present have my plasma wall mounted and have been looking at redecorating the room.One feature I would really like to add is a electric fire with full surround under the screen.Ive seen this loads of times in the "get your plasmas out" thread and was wondering what if any problems you have had regarding the heat from the electric fire ? Secondally short of having to get another plug wired in I would need to run the fire from the same power socket as the plasma.In total I would have Plasma,dvd,PS2 and the fire all on one adapter from one plug.Not knowing anything about loads etc can anyone advise if this would also create a problem?
    thanks guys
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,214
    Staffordshire, UK
    +69
    I'll let the install experts give you the full info, but in general I'd say the following:
    You'll need a hefty shelf/mantelpiece etc above the fire to disperse the heat from the fire away from the plasma.
    Electric fires draw a pretty heavy current load. I wouldn't be too happy having it run from the same socket. Could ask a sparky to perhaps run out a spur from the supply cable to a separate socket with own fuse.
    Picture quality may be affected by the heavy current from the fire. A good quality mains filter could be a good idea.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    not a problem if done properly.a feature fire and a working fire are different things. We advise not running both at the same time! Get a sparky to put some more sockets in, we will only ever connect plasma's to there own switched socket where possible and other kit off another socket. And fire off another.
  4. betamac
    betamac
    I have my plasma above a coal fire
    and was wondering if it will do any damage to the plasma when its going through the winter?
    i have attached a picture below, i know the wall behind the plasma stays cool when the fire is in use as i tested that
    theres no way the heat from the front could damage it is there? i would rather freeze than damage my plasma lol
    http://www.apal82.dsl.pipex.com/Panny Pic 1.jpg
  5. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    Thanks alot guys. :thumbsup:
    I thought this would be the case with overloading the plug.Guess 1st thing is to get a sparky in to add a few more sockets. As for the heat,the surround is quite a chunky piece so I hope this will help disperse the heat away from the screen
  6. atacam
    atacam
    Jul 19, 2004
    460
    Southned on Sea
    +9
    :eek: I have my plasma running through an extension socket, it is plugged in alongside 4 other pieces of equipment. In all I have 9 pieces of equipment cominig out of 1 double socket. am I in for some trouble?
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Not really no. They don't draw much current, but can feed interference back into the mains. That's what all those ferrite cores are meant to help with. If you have mains hum problems that's why, if you have no problems why should they start now, so let sleeping dogs lie.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ideally give it a seperate mains feed but we do have to run them off 4 ways now and again! When you are fitting active speakers you use lots and lots of 3 pin outlets! Beta mac if you read the manual you will see an operating range for temp if the air around thw
    e underside of your screen is within 5 deg of max i would be cautious. If it is below that then be gentle with the screen. these things run in saudi etc but the drive for quieter units with no fans has reduced the cooling capacity of the unit.
