Plasmas above the fireplace
Discussion in 'Plasma TVs Forum' started by mark raeburn, Jan 21, 2003.
  1. mark raeburn
    mark raeburn
    Nov 14, 2002
    413
    +19
    I am going to mount my panny 5 series over the fireplace when I move into my new house. Although this is a working fireplace I had not planned to use it (due to the heat issue on the plasma). However according to this website it's only harmful to the plasma if it's turned on, and if the temperature diurectly behind the screen is 90 degrees of greater.
    http://www.plasmatvbuyingguide.com/plasmatvreviews/plasmatv-fireplace.html
    Can anyone confirm that this is correct?
    Mark
