Dunwa
Established Member
Okay i'll throw this question out there.
Should plasmas be mounted above radiators or above fireplaces. In a lot of the promotional material you see the happy couple sitting by a roaring fire with a plasma (usually switched off) mounted on the chimney flu.
I'm currently working out the best place to mount my plasma and there are two options. 1 is above a 1M double rad and the other other is on a bare wall.
My gut feal tell me mounting it above the Rad is a bad idea ?
