plasma + xbox + wall mounting = wiring advice needed
Discussion in 'Home Cinema Buying & Building' started by gdi, Sep 12, 2005.
  1. gdi
    gdi
    HI
    I am wall mounting my plasma (42PD6600) and would like to connect this to an xbox, for the moment... My thinking is to run the leads (power, aerial, 2*scart, hdmi, is this enough) out benind the plasma to an external wall, along the wall and then back into the room and connect to my xbox.
    Is this possible, will it work and any advice, tips most welcome.. :rolleyes:
  2. Not A Clue
    Not A Clue
    have a search of the forum - i remember reading in one of the threads potentially issue about running internal cabling externally
