Plasma/XBOX problem
Discussion in 'Plasma TVs Forum' started by Johnny Thunder, Mar 18, 2005.
  1. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Hello all, having a bit of a problem.
    I posted this in the Console gaming forum, but I am not sure
    if it could be a setting on my display. Hope someone can help.
    Check out THIS thread.
    Thank you.
    Johnny.
  2. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Hope you can help me guys.
    I now have all my problems sorted with my xbox.
    When I enter the settings menu on the xbox, and activate
    480p, 720p and 1080i, my display is giving me a small picture
    in the centre of the screen with large grey bars on all 4 sides.
    Is there something I need to adjust on my display.
    Thank you.
    Johnny.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    tis quite a common issue unfortunately, not sure if anything can be done, but consoles just dont seem to work on Full 16:9.................the black frame seems to be omni present
  4. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Gutted..............
    I have gone through all this aggro and cash, for hidef, and it doesn't
    work.... :thumbsdow
    I get a full screen picture with the hidefs deactivated, but, as soon as
    I activate them this happens.
    Oh well, back to the drawing board........
    Cheers.
    Johnny.
  5. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Could someone please explain this to me.
    When I activate the hidef settings, am I just getting 640x480...?????
    Johnny.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    dont you need a US disc for HD output?
  7. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    :blush: I haven't got a clue.......
  8. cboy
    cboy
    Dec 29, 2004
    559
    +4
    yes u do none of pal releases are hd so u need ntsc releases of the games to be hd....
    and a modded xbox... :D
  9. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    So if I get a Region 1 game, it will fill the screen, is that right.
    Thanks for your patience.......... :smashin:
    Johnny.
  10. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    I have nearly the same set up. Mine is switched to NTSC via enigma, all the hidef modes are activated in the MS dash and when I play a game it plays in 480p instead of 480i. I believe Soul Calibre and Enter matrix are pal games which support hi def up to 1080i. There is a list somewhere if you do a search.
    I know we have diferent screens from the same family but my games fill the screen. The box you describe with grey boarders is similar when I switch my screen to 4:3.
  11. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    I believed that it should be full screen in progressive, but that does
    not seem to be happening.
    Surely this is a setting on my screen..........????
    Johnny.
  12. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    Hardwicke and Wotton
    +349
    certain games will always have borders, soul calibur2 for one, in 720p on my sanyo z2 has borders ( mainly due to it being in 4:3)
    other games will have slight borders on the left or right or both some fill the whole screen, annoying yes, but its one of them things.
  13. cboy
    cboy
    Dec 29, 2004
    559
    +4
    wat dashboard u using avalaunch or evox?
    i know in avalaunch u can select wat output and in xbmc u can select the same aslong as its set properly in the ms dash
  14. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Using standard ms dash.
    When I say borders, I mean big grey borders with something like
    a nine inch picture in the middle of it........ :confused:
    I just thought it must be a display setting, but other than altering
    basic settings, I am a bit afraid to mess with anything that I do
    not understand.
    Johnny.
  15. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    HERE is a screenshot with hidef activated.
    Johnny
  16. Taz69
    Taz69
    Apr 15, 2002
    3,258
    Bristol
    +304
    as I said in the other thread, I think you will find its only NTSC games that are encoded in Hi-Def, if you look here its the list of games that support hi-def, http://www.hdtvarcade.com/xboxlist.htm but I have read somehwere that PAL games do not support Hi-Def as there was no need as it was disabled in the PAL xbox, maybe wrong thou, but pretty sure thats what I read.
    Taz
  17. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    +349
    nah, most pal games do progressive scan aswell, bill gates in his wisdom "removed" the pro scan feature from uk xboxes (bloody tit if u ask me) the feature is in the games just only the lucky modded and import xboxes can see it.
  18. stevelup
    stevelup
    Aug 13, 2002
    6,506
    Swindon
    +1,078
    What you are seeing is to be expected. You're forcing your XBOX to output 720P but playing a game which only supports 480p/i
    Almost all games will work at 480p which is a noticible improvement over 480i - your efforts in going Hi-Def are definitely not completely wasted.
    I don't think there is a single PAL game which runs at anything above that.
    There are quite a few US disks which run at 720p and a small handful which run at 1080i.
    Follow the link that Taz69 gave you - there's a comprehensive summary on that site.
    Steve
  19. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Thanks guys.
    That shot of the screen is with 480p ONLY activated, and I thought
    PAL games would run at that. I just could not understand why the displayed area is so small, considering when I deactivate 480p, I get full screen image.
    Johnny.
  20. Twan1
    Twan1
    Dec 19, 2004
    1,195
    38
    Essex
    +22
    Hi johnny,
    not sure why ur havin this problem! your display and xbos can run in hi def, pal games can definately run in hi def too!
    i have the pio 50mxe1 with a soft modded xbox but run the xbox through a lumagen hdp pro but it seems fine.
    have u tried to change the signal output on the plasma then put it back again? it might need re syncing to run in hi def???
    not sure what else it could be
  21. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    How do I do this Twan.
    Thanks.
    Johnny.
  22. Twan1
    Twan1
    Dec 19, 2004
    1,195
    38
    Essex
    +22
    just go into the menu and change the signal format.
    If this doesnt work i would try giving pioneer tech a call as you shoyldnt be having these problems surely????
