Plasma wall mount
Discussion in 'Home Cinema Buying & Building' started by remdies, Apr 23, 2005.
  1. remdies
    remdies
    Is anyone using vantage points new mounts. I live in the UK and this seems like the only place to get them from:
    www.appitecs.com/vantage/
    Anyone got any comments on the mounts?
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    It's way cheaper to buy a mate a beer or 2 to help you use a conventional mount. £300 is way over the top for a mount, the going rate is £100 or less.
  3. remdies
    remdies
    No your not getting me down just after quality kit. I am not bothered about price as long as the gear is up to the job!
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    It's only a bit of pressed steel, for god' sake! Spend money where it makes a difference, buy a scaler, a better amp, better speakers, the wall mount, they are all up to the job. A 42" plasma weighs 30 kgs.
