Plasma Wall Mount - Will it Work???
Discussion in 'Home Cinema Buying & Building' started by Vinesh, Jun 7, 2004.
  1. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    I will be getting my plasma very soon (TMF)
    I have a question about the wall mount option. I currently have a dado rail at 1m high, but I want the plasma to be mounted about 80cm from the bottom of the screen.
    To clear the dado, I can put battens between the wall and the bracket. Will this methotd make it less secure?
    I am looking at the powerbuy bracket.
    Another option is with this bracket:
    http://av-sales.co.uk/plasma/html/universal_tilting_wall_mount.html
    I can have the back plate sitting on top of the dado and screwed into the wall without any battens. As this bracket is 5cm deep, it will clear the dado.I assume the side bits holding the plasma sticks out by 5cm (?). This will give me the required height as well.
  2. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Just looked at av-sales site. The second option doesn't support Pioneer screens. :suicide:
  3. PC Nut
    PC Nut
    Jan 11, 2004
    649
    South West
    +65
    If mounting on solid wall ie: Solid bricks/breeze blocks and plaster, it should be fine just use longer fixings. Fixing straight to wall i would use 4 raw bolts of +130mm by M10 allow more length for you battons.
    The above mentioned power buy gives you about 20mm clearence.
  4. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Dear fellow tarmac terrorist, those are the bolts we use generally. Don't order them too big, holes in plasma wall mounts are surprisingly small, usually 6 or 8 mm.
  6. scoooby
    scoooby
    Mar 22, 2004
    104
    Always possible to take a drill to the bracket and enlarge/create holes.
    (With care!)
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Certainly, but it's easier to buy the right size bolts...
  8. scoooby
    scoooby
    Mar 22, 2004
    104
    Even Easier to get yourself a 5" casio and prop it on your desk.
  9. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Thanks for the input.
    Maw - Are these bolts available else where. With screwfix you have to spend over £45 for free P+P. I have already spent loads with them.
    Scooby - Dont like the desk stand.
    This is for a Pioneer MXE-1
  10. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Another q Maw-
    What size bolts would you use?
    The slim bracket accepts size 10 bolts, nut sure on the length.
  11. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    We buy them from screwfix, I daresay they are available elswhere if you look. Is carriage that much? Our average order is £2-300 so I haven't a clue.
  12. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Maw - Any ideas on the length of the bolt?
  13. PC Nut
    PC Nut
    Jan 11, 2004
    649
    South West
    +65
  14. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Cheers PC Nut.
    I will check out B&Q/Screwfix website
  15. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    We use 75mm bolts from choice, you'd better extend that by the depth of the packing. It's overkill, so that will be enough even allowing for any extra strain. I have a technician who reassures the customers by doing a few pull-ups on the bracket. We've never had to re mount one.
