plasma wall bracket from av-sales???
Discussion in 'Home Cinema Buying & Building' started by foxyuk13, Oct 8, 2004.
  1. foxyuk13
    foxyuk13
    Sep 23, 2004
    207
    +9
    has anyone bought one????
    looking for one for my samsung 42 inch ....... easy to fit??? good quality???
    help
  2. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    I'm presuming it will be the same as the one i bought with my PW6, very easyy to fit, 8 holes to drill and a plate which mounts on to the back of your plasma which then simply hooks onto the wall mounted bracket. :)
    Quattro
  3. ROSA
    ROSA
  4. stephinson
    stephinson
    Sep 28, 2004
    55
    brill thanks I was going to make my own but at that price why bother :clap:
  5. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    One point to note with this bracket, when mounting use a small spirit level on the bar that the plasma hooks onto and not the top of the plate when marking out for drilling :)
