Plasma TV's
Discussion in 'Plasma TVs Forum' started by common, Mar 1, 2002.
  1. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    I'm thinking about a Plasma screen as my next purchase.
    How would I connect my Sky digibox to it ? My processor has s video in & out, component in & out and composite in & out.
    I would use component for my DVD player, but I am unsure about Sky
    I looking at the current 42" Panasonic - is this regarded as one of the best value Plasma's ?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    Common
    Just about every Panasonic TH-42PWD4EX or TH-42PW4B we sell goes out the door with an RGB to VGA converter box to allow hook up of a Digibox on RGB (+Composite sync).
    I am assuming here that you will not be hooking in a PC to the plasma panel - if you are then you will have to go S-Video from your Digibox.
    We sell the converter boxes:
    http://www.tmfsolutions.co.uk/homecinema_signalconverters.htm
    or you can buy direct from:
    http://www.rgbtosvideo.com/.
    Best regards
    Joe
    [email protected]
