Plasma TV
Discussion in 'Plasma TVs Forum' started by smithid, Jul 26, 2005.
  1. smithid
    smithid
    I recently bought a 37'' Panasonic Plasma TV and after it was delivered I noticed a 3'' scratch on the lower right hand portion of the screen. The scratch doesn't appear to be very deep and is not visible when the TV is on. I called the company I purchased the TV from and they offered me $600 to keep the TV as is. Is this scratch going to cause problems over time? It currently is not noticeable when the TV is on. Should I be concerned about any long-term effects of this scratch? Is it worth giving away $600 price decrease to get a new item delivered?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I doubt the scratch would cause future problems. If it's worth keeping (and getting a discount) is something you need to decide for yourself though.
  3. Kaminsky
    Kaminsky
    Apr 26, 2005
    23
    The scratch shouldn't be too much of a problem but you never know, I'd be worried about long term corrosion ie. rust. Also be careful, sounds like the retailer is trying to pull a fast one...I would ask for any refund to be given in sterling.
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    even if smithid is in the States? :)....and I don't think glass rusts.......personally I'd take the cash if it wasn't bugging me whilst viewing
  5. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    I'd have to disagree with you mep.It's been scientifically proven that glass does actually rust in certain American States !!
    Smithid. I'd say $600 is a great refund as long as it definately can't be seen when the plasma is turned on.
