Plasma TV - which is the best?
Discussion in 'Plasma TVs' started by wacky, Apr 21, 2005.
  1. wacky
    wacky
    For a few months I have been looking at plasma TV's and hoping that prices would come down whilst I decide. I seem to be hooked on a black table top Pioneer PDP-435XDE set with the black speakers on either side. Ive seen prices around the £3k mark. I do not know anything about TV's at all other than that you pay for what you get. To some a Tiny model is a bargain, to others its a waste of money. Some tell me to go for Sony , others LG or Panasonic. Whats the best around and where can i find a trustable internet seller.?
  2. zest
    zest
    Jan 24, 2005
    147
    16
    kenilworth warwickshire
    hi, the new Panasonic VIERA TH-42PV500B looks good out next month
  3. wacky
    wacky
    thanks mate, where do you suggest i buy from and why that model over the pioneer xde ? I don't know one from another? just curios to find out.
  4. Cwhelan
    Cwhelan
    Jan 29, 2005
    141
    16
    Milton Keynes
    For me it was either a Panny or Pio. I choose Pio.
    Goto your nearest AV dealer (or at least a recommended one). They can also do the Install for you normally if you are not confident doing it yourself! They are big awkward buggers to get on a wall! you'll definitely need two of you if you are lifting one yourself!
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
  6. rudy
    rudy
    Jan 2, 2005
    499
    Panny 500 will be number 1 on demo list
  7. Desticado
    Desticado
    Oct 16, 2000
    1,474
    41
    Canterbury, Kent, UK
    +6
    I know the 500 is out in May, but does anyone know when in may?
