Plasma TV - is it possible to convert for HD ??
Discussion in 'General TV Discussions Forum' started by Seanjackdan, Mar 25, 2006.
  1. Seanjackdan
    Seanjackdan
    I am new to this forum, and have a question which may sound silly to most of you.
    Last year, I bought a Panasonic "Viera" TH37-PE30 plasma TV for £2500 with Panny DVD-Recorder, etc... and also have Sky+
    Now with the gradual introduction of "HD" is there anyway I can convert my "Viera" plasma TV to be HD compatible, or is my "modern" new TV gonna be "out of date" soon.
    I can't afford to buy another viera that is "HD Compatible" when I have a stunning TV as it is, but just thought it may be possible to "upgrade" !!!
    Kind Regards........
    Sean !!!!!!!
  2. scarty16
    scarty16
    Jul 1, 2003
    1,570
    +399
    no upgrades available
    check your manual to see if your tv accepts the following:
    720p @ 50hz & 60hz
    1080i @ 50hz & 60hz
    then you will know whether your tv will be able to accept a HDTV signal
    ps: ignore anything that says "HD Compatible" only go so a TV that says "HD Ready"
  3. Seanjackdan
    Seanjackdan
    Thanks for info, I will check manual, and advise what it says - cheers !!!!
    Sean !!!!!!!
  4. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,595
    +920
    Also - check the native resolution of your display.
    Even if it accepts 1080i or 720p, if it has a resolution of something like 850x480 , rather than a minimum resolution of around 1024x720, then you will still be watching HD converted to something near SD. Not that this will look awful - it just won't be "HDTV".
  5. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,222
    83
    Over the Hill & Far Away
    +140
    But it will look very very good...it may be sclaing down to the panels res. but the source its sclaing from is better.
    Even the "HD Ready" have to scale hidef picture to the panel one way or another. Theres very few which are natively "HiDef"
    Matt
  6. daftmole
    daftmole
    Oct 6, 2002
    2,200
    kent
    +398
    Hi I own the Panasonic "Viera" TH42-PE30 and have just had Telewest's TV Drive installed. It's ouputting 1080 via component and I am blown away by the results! Some of the HD programmes via Teleport are stunning especially Pride. Normal (SD) channels are also very, very good - even the missus notices the difference!!! Upgrading the TV has now been pushed out of my mind, I'm more than happy with my plasma!!!
  7. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    I doubt you'll be able to watch any HDCP material tho (Telewest movies?).....which is about the only downside to non-HD plasmas.
  8. daftmole
    daftmole
    Oct 6, 2002
    2,200
    kent
    +398
    shaithis - You are correct, but to be honest I have most of the films on dvd already!!!
