plasma tv connection advice wanted please
Discussion in 'Plasma TVs Forum' started by mickymcd, Oct 19, 2005.
  1. mickymcd
    mickymcd
    Sep 5, 2005
    929
    boro
    +38
    Hi i need some guidance on best configuration and cables for my plasma tv its the relisys RP42AB30 unit it has the following connections at the rear
    rgb analogue port(pc type)
    dvi port(pc type dvi)
    composite(video tellow phono style)
    s-video
    component(reg/green/blue connections)
    scart 1
    scart 2
    tv ant input
    i have the following equipment
    panasonic e50 dvd recorder it has (2 scarts)
    pioneer dvd player (has 1 scart video composite scart rgb component reg/green/blu)
    ntl box (has 2 scarts)
    xbox 360(full system) on its way if it arrives
    netgem freeview box (2 scarts rgb)
    what would be best way to stick all this in to get the best from my screen? as later one want to bury all cabling into wall etc i may have to buy a sort of splitter to share some connections maybe? im all ears for your advice ive just got dvd and ntl box connected by scarts at the moment. thanks
    [​IMG][/IMG] :hiya:
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Simple. Buy a scart switch. Quintro from Lecktropaks looks good, check which scart is RGB. Enable RGB on all your stuff. When the X-box comes, that goes on component. Anything you want to record, you can connect with another scart to the 2nd scart on the DVDR. I guess that'll be NTL.
  3. mickymcd
    mickymcd
    Sep 5, 2005
    929
    boro
    +38
    thanks for that do you have a link for it thanks cant come up without googled thanks :smashin:
  4. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
