Plasma Tuner
Discussion in 'Plasma TVs' started by js1, Dec 30, 2004.
  1. js1
    js1
    I have a JVC 42PBW plasma screen which is tuned in by my DVD recorder/Sky box as it doesnt have its own tuner box. I want to also connect a video so I can record on the DVD and watch a different channel. Is there a tuner box/accessory I can buy which will enable me to do this? Alternatively how can the video be set up to act as a seperate tuner?
    thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    RS sell a daewoo tuner box but search for ProV and ProV+ they are tuners for VGA monitor so as long as you have a spare VGA input you will be fine (or a Freeview BOX.........) see www.freeview.co.uk to check coverage
