Plasma tuner question
Discussion in 'Plasma TVs Forum' started by CARLOS, Dec 29, 2003.
  1. CARLOS
    CARLOS
    Feb 11, 2001
    6,457
    WEST MIDLANDS
    +1,412
    Thinking about a Plasma but would like a tuner as i use teletext a lot, The problem is the tuners are quite expensive.
    So i wondered if its possible to use something like a ProV+ as a tuner if so does anyone use one and how good is it ?
    Any comments appreciated.
    Cheers, Carl
  2. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    I have a Pro V+, it's rubbish!!!!!! It's about to go in the bin.
    I would get a Freeview box, something with S-Video (Pioneer or Sony), they use digital teletext..
  3. CARLOS
    CARLOS
    Feb 11, 2001
    6,457
    WEST MIDLANDS
    +1,412
    Thanks for the reply
    The only problem is i think the Digital text service is crap compared to the current analogue one !
  4. bobbypunk
    bobbypunk
    most plasmas come with a tuner now. I don't know if they're compatible with the new machine, but the tuner box for the Panny 5 are going cheap everywhere.
