Plasma + thermalite + articulated wall mount installation
pornstar
I've been reading around this forum to find out the best way to secure a Vogel EFW6325 (with TH37PX60) articulated wall mount to a thermalite wall.
I've just rung Fischer fixings tech support for advice and they are recommending using Frame Fixing FUR (which can take load up to 30kg) or Twist Lock Anchor (which can take load up to 40kg). However, they said it depends on the bracket mount size and distance from wall.
I've read on this forum a number of people using the Twist Lock Anchor, but would like to hear from someone who has used them with an articulated wall mount.
So, has anyone else had this problem? If so what fixings did you use?
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
