Plasma Tellies
Discussion in 'Plasma TVs Forum' started by Mr Sunny, Nov 2, 2004.
  1. Mr Sunny
    Mr Sunny
    Quite simply if i have £3000 to spend on a 42" plasma which is the best one to buy.
  2. bobbypunk
    bobbypunk
    IMHO Pioneer PDP434HDE.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OR Panny TH-42PE30B Veira depending on what you watch and want..........
  4. Leerca
    Leerca
    Sep 15, 2004
    7
    Sony KE-P42XS1. PQ is very good and it looks stunning in the livingroom.
  5. Mr Sunny
    Mr Sunny
    Thanks all will check out specs/rewviews etc on all 3
  6. Todda
    Todda
    Does it have to be a TV (i.e. with tuner), or would you be happy with a display.
    If you have Sky or Freeview I would definitely take a look at the Panasonic PHD7.
  7. Mr Sunny
    Mr Sunny
    cheers todda after consideration needs to have tv tuner, been looking in depth at panasonic TH-42PE30B looking good best price i can find is £2374 unless of course anyone knows better
