Plasma storage
Discussion in 'Plasma TVs' started by llanellijack, Oct 27, 2003.
  1. llanellijack
    llanellijack
    I purchased an Hitachi 42PD3000E some weeks ago with the intention of hanging it in my new house but now my house move has been delayed by 4 months and I will have to put the plasma in storage. Thing is, the room I am storing the plasma in has vitually no heating .. but is not damp. The plasma is still boxed in it's original packaging. I'm worried that, as the temperature will drop through the Winter, it would cause damage to my plasma in some way. I've covered the box with sheeting but have left holes uncovered for ventilation. Any idea what the lowest temperature that these things can be stored under, the manual just seems to warn about high temps. Any thoughts please ?
  2. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    should not be a problem.
    before you bought it , it was just sitting in a warehouse and if it was assembled outside uk probaly came over in a boat.
    so id say dont worry. better that it dosent go from very hot to cold.(which it would do when in operation.
    Sides it will still be coverd by warranty so no worries eh!
  3. llanellijack
    llanellijack
    sounds good, thanks for that. I've only got Hitachi's 1 year warranty on the TV, half of which will be up before I get to use it :( was just getting worried. Cheers,
    dean.
  4. Mo-S3
    Mo-S3
    Jan 24, 2003
    87
    cheshire
    on the hitachi 42pma400e the specs are as follows :
    Temp :storage : 0 deg to 40 deg C
    Rel Humidity :storage : 20% to 90%
    Hope this helps
  5. sjallen
    sjallen
    All I'd add is try to keep it upright if possible.
  6. llanellijack
    llanellijack
    thanks all for the advice :)
