Plasma Stands
Discussion in 'Plasma TVs Forum' started by loadsofleads, Jun 21, 2004.
  1. loadsofleads
    loadsofleads
    Are all plasma stand universal, I mean are they interchangeable. Could you use a Pioneer stand with a Hitachi for example. I'm guessing not but it would be good if you could choose your own configuration. ;)
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    That would be far too easy. Wall mounts are all different too, though being basically a flat sheet of metal with holes, they can be designed as universal by making lots of holes. Desktop stands vary in their attachment method, some use the wall mounting holes, some have their own holes, and some, like Panasonic have alloy legs that fit in a strangely satisfying way into holes underneath....
