Plasma Stand
Discussion in 'Plasma TVs Forum' started by cjarmstrong, Mar 14, 2005.
  1. cjarmstrong
    cjarmstrong
    I have been trying to find out the dimensions of the panasonic stand produced by alphason model no:tystlocal1, called panasonic who said it didnt exist! even though its in there brochure! Also want to know does this stand fit the pw7.
  2. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    Have a check on the 'unbeatable' website, that's were I saw it last. Its been discontinued from there though but there are a few other places are still selling it.
  3. cjarmstrong
    cjarmstrong
    yes seen it there, I have found a retailer but they have no info on product i.e dimensions and whether the pw7 fits. They have also tried contating panasonic but with no result.
  4. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    I have one and it will fit the PW7. I believe it is discontinued as well. Mine will be up for sale shortly as my PW6 is going on the wall. PM me if you are interested.
  5. jwillans
    jwillans
    Parklife - Is it black? If so I would be interested if cjarmstrong isn't.
    James
  6. cjarmstrong
    cjarmstrong
    really need one asap as plasma standing on poly blocks that come in packaging! are the fittings on the pw6 the same as pw7?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Panny are VESA mountings (international standard) and the PW6 and 7 mounts are the same so it will fit, very nice stand too if you can find one!!!
  8. cjarmstrong
    cjarmstrong
    heard pack form panasonic technical dept this morning who left a message to say it was designed for pw6 and would not fit pw7? I think I'd rather take the word of HD on this though.
  9. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    jwillans - It is silver not black. Check out http://www.unbeatable.co.uk/CatalogueItem_16373.html for a picture
    cjarmstrong - I can confirm that the mountings on the back of the PW7 are exactly the same as the PW6. This stand was originally designed for the PA20 and Panasonic even told me it would not fit the PW6. The 2 arms that you screw through to attach the plasma move up and down independently and have about a 6 inch long hole to attach. I would say that this stand would fit a lot of plasmas, not just the PW6 and PW7.
    If you are after one immediately then Alphason have bought out a similar model. Check out http://www.alphasondesigns.com/products/ag942s/index.shtml
    The arms on this look the same as my TYSTLOCAL1 so here you can see the flexibility of the stand.
  10. cjarmstrong
    cjarmstrong
    cheers parklife ordered the tystlocal1 today will take a couple of weeks to come though, so my gear is on the floor with the screen on a couple of poly blocks for a while longer.
