plasma stand shelf height?
mo
hi,
i wonder if anyone can solve this without it getting too expensive.
i need a glass plasma stand with the shelf of the next shelf(the one directly under the plasma shelf)to be 35 cms.
i need this so that i can house a b&w700 series centre in there.
as you may know the height of this particular product is high because of the way the tweeter is set.
other than getting it custom made(costs alot!)is there anything out there now.
neiljones
Originally posted by mo
hi,
Go on to the Vogel website
They do an excellent selection ofwall brackets, and equipment storage shelves together with matching trunking.
Beautiful finish-have seen on display in very large Curry's superstore in Speke Retail Park in Liverpool. Dig deep
mo
thanks for the reply.
an open stand is not what i'm after.
within the stand i have to house the pioneer tuner,sky box,the 868,the ax5 and a dac.
things just got a little harder hey fellas!
thanks for trying and any other help would be most grateful.
M
MPBayless
Have a look at Optimum stands. They have AV stands with 2,3 or 4 shelves with spacings of 17, 230 or 400 mm.
BKATZ
Have a look at my pic on "get your plasmas..."
I used four Ikea units bolted together (could have got away with three, but the forth houses my Rega 3)
Might or might not be suitable for your taste?!
B.:)
LG CX 4K OLED TV Review: The best TV of 2020?
