plasma stand question
Discussion in 'Home Cinema Buying & Building' started by johndoe1, Oct 28, 2004.
  1. johndoe1
    johndoe1
    Aug 25, 2004
    2,435
    48
    +46
    does anyone know of a table top stand for a 37" panasonic plasma that has two seperate feet as opposed to the one solid stand?
    reason being - I want to put my m&k k7 center speaker directly under or in front of the plasma (instead of hide it in my cabinet) but it blocks part of the screen.
    k7 measures 5" high so clearance would need to be this.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Richer sounds sell some feet you bolt on to the wall mounting points. Not especially attractive, but then whose feet are?
  3. johndoe1
    johndoe1
    Aug 25, 2004
    2,435
    48
    +46
    cheers MAW - just had a quick look on the website - can't see em? dont suppose you could point me in the direction....
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Can't see them either. We bought a set cos we take screens to peole's houses to demo, they fit anything. They were £50, about 4 months ago.
  5. johndoe1
    johndoe1
    Aug 25, 2004
    2,435
    48
    +46
    just called em - they are by partington - or should i say were - -they are now discontinued...
    the search goes on.
  6. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    I am just having some gash feet made from angle (because my brother's welding guy is away until next week). If these are OK and I still want feet I will get some made up from something like 30x10mm steel strip. And sprayed black. I can't promise what the finish will be but if no-one else is making them I can ask him how much heill knock up some more for.
    Anyone else ?
    Is this anything like what's wanted ? (and what is the pitch 'P' for my pwd6 that arrives tomorrow?)
