Plasma speakers as Presence speakers
Discussion in 'Plasma TVs Forum' started by Stimpy, Aug 23, 2004.
  1. Stimpy
    Stimpy
    Don't know if this is the right forum or not, but here goes
    I've just got myself a new AMP (yamaha DSPAX750SE)
    and it support the option of either having rear effects speakers (7.1)
    or a pair of from Presence speakers (driven via internal DSP modes).
    Given the wife exeptence factor I can't have any more speakers for the rears,
    so I was wondering could I use the speakers built into the plasma (which one depends on my insurance company)? It is obviously possible, but would it sound good???
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    I don't think it would be worth it, the Yamaha tends to want front presence speakers a bit wider than attached to the sides of the screen and they will be very imbalanced from the rest of the speakers you are using. The potential is to make everything sound worse rather than better IMO.
