plasma speaker switch
Discussion in 'Plasma TVs Forum' started by rab4169, Jul 7, 2005.
  1. rab4169
    rab4169
    Dec 12, 2004
    533
    i have 1 set of speakers in my room on wall brackets.
    to these speakers i would like to run my amp to them but also the output from my panasonic plasma speaker terminals.
    i have fitted a speaker switch but when i put on the plasma the sound comes through them for about 5 seconds and then clicks off.
    it is all wired correct, do you think i need a quality speaker switch as it seams this one even though put to plasma input is causing some kind of overload or short.
    what is a good quality speaker switch?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
