Plasma sizes with stand and speakers
Discussion in 'Home Cinema Buying & Building' started by loadsofleads, Nov 1, 2003.
  1. loadsofleads
    loadsofleads
    Could anybody please post the total height with stand and total width with speakers for the following plasmas,
    Pioneer PDP-434HDE
    Panasonic TH42PA20B
    Philips 9965
    My new plasma is going in the loft which has angled ceilings, I just need to check if it will fit ;)
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Both the Panasonic and the Philips have the speakers built in, so the width as shown on their specifications (see their web site) is the total width. (Not sure about the Pioneer).
    For height - the Panasonic pedestal stand adds approx 5 cm (2 inches) in height. Height without the stand is 65.8cm, so with approx 71cm.
    http://www.panasonic.co.uk/plasma-tv/th42pa20b/index.htm
    Mark
