plasma size
Discussion in 'Plasma TVs Forum' started by lnewey6, Oct 19, 2005.
  1. lnewey6
    lnewey6
    Nov 10, 2003
    196
    derbyshire
    +3
    what size screen should i go for with a 10 foot long living room and what are the best screens at the moment i have a budget of 1500 pound thanks
  2. Blue Triangles
    Blue Triangles
    Sep 19, 2005
    1,002
    +82
    I have just over 10 feet of viewing distance. I've ordered a 50" screen.
  3. av2diefor
    av2diefor
    Normal distance of about 8/10 foot, for most people (i'm assuming here), if you can afford it and the family are behind you a 50" is bliss.
    And anyone who disagrees are wrong :D
  4. golden phoenix
    golden phoenix
    Aug 29, 2005
    12,741
    7
    2
    cheshire
    +5,048
    [And anyone who disagrees are wrong] :D
    Like your style
    :rotfl: :rotfl: :rotfl:
  5. sabujo
    sabujo
    trust me: whatever screen size you choose, you will become acostumed to it in less than a week and start thinking "...humm, its not THAT big after all, maybe i should have bought a screen with a couple more inches."
    If you can aford it and it is not ridiculously big for your wall, go for it. The bigger the screen the more realistic will be you movie and tv watching experience. Just make sure your tv signal is as clear as possible cause big screens show off broadcasting imperfections like picture noise easily.
  6. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    Whilst a nice luxury I don't think £1,500 will buy you a 50" :lesson:
    You are looking at a 42" which is a nice size over that distance - same as me :smashin:
    The search function is your friend in regards to which plasma to go for, it depends on your set up and preferences. :)
  7. Sandman
    Sandman
    Nov 28, 2002
    3,778
    Glasgow
    +1,716
    A 50" screen might seem a little overpowering in a room that size (especially if it is stand mounted). I would suggest a 42" screen and mounting it on the wall would be the perfect size for you.
    If you have an external tuner (sky or freeview) and a surround system for sound then you can get the panasonic PW8 for that price. It is a great screen and it HD compatible (means it will display a HD signal in a SD resulution). Go to the power buys forum and see the members deal on this screen.
  8. Norbert666
    Norbert666
    Dec 15, 2004
    168
    +4
    I sit about 3m away from my 50".
    It is in now way overpowering.
    In fact, my room is a lot bigger since I got rid of the 32" CRT and replaced it with this. :)
    get as big as you can afford.
  9. theo cupier
    theo cupier
    Sep 18, 2004
    1,670
    63
    Amersham, Bucks
    +113
    Agree with norbert666. I'm 8ft away from my wall mounted 42in screen and I'm already pining for extra screen space!
    Also, the amount the room has grown since we got rid of our 28in widescreen & its ugly table and re-arranged the kit racks against the wall is incredible..
    Many pepople will say "I wish I'd bought a bigger screen" I don't recall seeing anyone say they wish they'd bought smaller. Work out what the biggest you can afford is and buy that (unless you can only afford 37in, in which case save up longer and buy at least a 42in!)
  10. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,287
    Chelmsford
    +558
    Just follow my set rule. You Can Never Have A Big Enough TV! :lesson:
    50" all the way!
  11. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    YES BUT HOW WILL HE DO THAT FOR £1,500 :eek:
  12. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,287
    Chelmsford
    +558
    Sell his wife on E-Bay!! :rolleyes:
  13. CheekyKid
    CheekyKid
    Apr 28, 2005
    684
    +20
    As a matter of fact a plasma is less demanding than any wife.Shall open an auction :rotfl:
