Plasma showdown
Discussion in 'Plasma TVs Forum' started by nonikandola, Dec 5, 2004.
  1. nonikandola
    nonikandola
    right iv narrowed it down to 2 models the sony PDP-435FDETE or the pioneer PDP-435FDE. forget about the price tag, which is the better screen
    i will be watching tv mainly on sky+ (footy especially and films).
    and playing on a ps2 or xbox
    really getting confused now because i had my heart set on a sony but its not hdtv ready and
    then a pioneer but now i read about lip sync problems. i will have a 5.1 amp but i dont want to be running it all the time so the tv speakers will be used.
    so which should i get.
    cheers
  2. teoterone
    teoterone
    There are only the 435XDE and 435FDE in the UK
    Major differences are the XDE has a freeview built in and the FDE doesn't, XDE has a silver media box with PC-input, it also has a Picture in picture and home gallery (where you can view pictures from your digicam memory) and finally a digital optical out. The FDE doesn't have any of these and its media box is black. There are a couple of more differences, you can compare both products at http://www.pioneer.co.uk
    The price difference is only £100 online. The XDE is better since it has more features and it doesn't cost that much more.
  3. nonikandola
    nonikandola
    what a kn*b i meant sony KDEP42XS1 vs the pioneer 435FDE
    sos guys
