Plasma setup !
Discussion in 'Plasma TVs Forum' started by edinburgh69er, Jun 5, 2002.
  1. edinburgh69er
    edinburgh69er
    Ladies and gentlemen,
    Having successfully found a bargain Amp and DVD solution on a trip to Singapore, my local Hi Fi dealer has had the benefit of a wad of my cash to complete the setup.
    I have a problem which only you guys could sort out.
    1x Yamaha AZ1 (yes, it's AZ, it's just out)
    1x Pioneer 737 DVD
    1x Panny 42PW4 with RCA board (no tuner)
    1x Sky Digibox (on it's way on Saturday)
    KEF Q5
    KEF Q9c
    KEF 2002 Sub/Sat (for rears plus sub) (aesthetic choice sorry / space was an issue)
    Firstly, the recommendation from the local installer was to put everything through the amp. So the DVD goes through it, as will the Sky box and a.n. other. The amp is then S-Video to the plasma.
    The plasma supports Component input for progressive scan but it's 5 channel (R,G,B plus Horizontal and Vertical). My DVD output is only R,G and B.
    The Sky box is SCART to RGB which will then feed to the Amp again.
    Anyone got any advice with these issues ?
    Muchos gracias,
    edinburgh69er
  2. Panicsony
    Panicsony
    Check www.RGBtoSVIDEO.co.uk they have a Scart to RGB converter I believe.
    Also Keene do both a cable and a box to convert to the RGB with sync on green or to a VGA input with H and V. www.keene.co.uk
