Quantcast
Plasma setup
J
jpd2
How do you connect your DVD / Freview box to your Plasma. I will be getting an hitachi with AV box, so don't want to go down the VGA route unless necessary.
I can't afford to go top end but need to be abe to connect a component and RGB scart, most low to mid range amps only have s video, so do I use this for just audio and not signal switching as this would otherwise degrade the signal.?
Any recomendations?
