Plasma Setup Newbie Advice
Discussion in 'Plasma TVs' started by miked1900, Jul 5, 2005.
  1. miked1900
    Am thinking about getting a Panasonic PV500 to use with Sky and a DVD player. I will be linking this up to a Denon amp with a 6.1 speaker setup. As I will be wall mounting this I want to plan how I will cable the setup before I purchase anything. My questions are:
    1, do I connect the amp to the plasma and then the DVD and sky into the amp? Or will it all be run from the TV.
    2. Are the Panasonics wall mounts the same as the third party ones?
    3. I have been told to purchase a more expensive scart cable but does the same apply to speaker cables?
    And finally when the cables (scart) are berried into the walls do these go into some sort for pipe of box? Or can they be sealed in without.
    Thank you
