Plasma screens and lip-synch delays?
Discussion in 'General TV Discussions Forum' started by [email protected], Jan 21, 2002.
  1. rob@rar.org.uk
    [email protected]
    Apr 29, 2001
    343
    16
    Hampton, Southwest London
    I'm in the market for a plasma screen (perhaps the Panasonic W4B). I vaguely reading somewhere recall that there were lip-synch problems when using plasma screens and seperate Dolby Digital/Pro Logic sound system. Is this correct, or have I made a mistake?
    Regards
    Rob
  2. Norman
    Norman
    Jul 14, 2000
    1,729
    116
    Herne Bay
    +587
    I can’t see why. The display should make no difference at all. If your current TV/Amp setup doesn't display any lip sync problems then adding a Plasma shouldn't change that.
    BTW, good luck on finding a Panasonic W4. If you want one and you know of someone who has it in stock buy it quickly because there aren’t that many about. My dealer told me not to expect any more of those units in quantity until March at the earliest.
  3. rob@rar.org.uk
    [email protected]
    Apr 29, 2001
    343
    16
    Thanks. After a bit more searching about I think what I read was something to do with line-scalers introducing a delay, so the potential for lip-synch problems if you feed a plasma through a scaler.
    Regards
    Robert
